Requirement : My Sole requirement is to convert any image file to tiff file from my C++ code. or Shell Script.
For this requirement i wanted test with ImageMagick.
1. Hi i have downloaded ImageMagic - ImageMagick.tar.gz.
2. Followed the steps given in http://www.imagemagick.org/script/advan ... lation.php
3. when i tried to make the file i got the error
Error
hyper24:~/imagemagic/ImageMagick-6.5.4-10 156> make
make all-am
make[1]: Entering directory `/x/home-new/smaruvada/imagemagic/ImageMagick-6.5.4-10'
CC coders/coders_art_la-art.lo
make[1]: *** [coders/coders_art_la-art.lo] Error 1
make[1]: Leaving directory `/x/home-new/smaruvada/imagemagic/ImageMagick-6.5.4-10'
make: *** [all] Error 2
Configuration Report
ImageMagick is configured as follows. Please verify that this configuration
matches your expectations.
Host system type: i686-pc-linux-gnu
Build system type: i686-pc-linux-gnu
Option Value
Shared libraries --enable-shared=yes yes
Static libraries --enable-static=yes yes
Module support --with-modules=yes yes
GNU ld --with-gnu-ld=yes yes
Quantum depth --with-quantum-depth=16 16
High Dynamic Range Imagery
--enable-hdri=no no
Delegate Configuration:
BZLIB --with-bzlib=yes yes
Autotrace --with-autotrace=no no
DJVU --with-djvu=yes no
DPS --with-dps=yes no
FFTW --with-fftw=yes no
FlashPIX --with-fpx=yes no
FontConfig --with-fontconfig=no no
FreeType --with-freetype=yes no
GhostPCL None pcl6 (unknown)
GhostXPS None gxps (unknown)
Ghostscript None gs (7.05)
Ghostscript fonts --with-gs-font-dir=default /usr/share/fonts/default/Type1/
Ghostscript lib --with-gslib=no no
Graphviz --with-gvc=yes no
JBIG --with-jbig=yes no
JPEG v1 --with-jpeg=yes no
JPEG-2000 --with-jp2=yes no
LCMS --with-lcms=yes no
LQR --with-lqr=yes no
Magick++ --with-magick-plus-plus=yes no (failed tests)
OpenEXR --with-openexr=yes no
PERL --with-perl=yes /usr/local/bin/perl
PNG --with-png=yes no
RSVG --with-rsvg=no no
TIFF --with-tiff=yes no
Windows fonts --with-windows-font-dir= none
WMF --with-wmf=yes no
X11 --with-x= no
XML --with-xml=no no
ZLIB --with-zlib=yes yes
X11 Configuration:
X_CFLAGS =
X_PRE_LIBS =
X_LIBS =
X_EXTRA_LIBS =
Options used to compile and link:
PREFIX = /usr/local
EXEC-PREFIX = /usr/local
VERSION = 6.5.4
CC = gcc
CFLAGS = -g -O2 -Wall -W -pthread
MAGICK_CFLAGS = -g -O2 -Wall -W -pthread
CPPFLAGS = -I/usr/local/include/ImageMagick
PCFLAGS =
DEFS = -DHAVE_CONFIG_H
LDFLAGS =
MAGICK_LDFLAGS = -L/usr/local/lib
LIBS = -lMagickCore -lbz2 -lz -lm -lpthread
CXX = g++
CXXFLAGS = -g -O2 -Wall -W -pthread
