[solved]problem with Magick++-config
Questions and postings pertaining to the usage of ImageMagick regardless of the interface. This includes the command-line utilities, as well as the C and C++ APIs. Usage questions are like "How do I use ImageMagick to create drop shadows?".
Post Reply
modou
Authentication code: 8675308
Post by modou »
Hi,
I'm a new user of api magick++, but when a try to compile a simple file with this command
g++ -O2 -o main main.cpp 'Magick++-config --cflags --cppflags --ldflags --libs'
i get this error :
g++: Magick++-config --cflags --cppflags --ldflags --libs : No file or directory of this type
And strangly I can obtain this result:
[mdia@olympe rotateTiff]$ Magick++-config --cflags --cppflags --ldflags --libs
-I/usr/local/include -fopenmp
-I/usr/local/include/ImageMagick
-L/usr/local/lib
-L/usr/local/lib -lMagick++ -lMagickWand -lMagickCore -ltiff -lfreetype -ljpeg -lpng -lfontconfig -lXext -lXt -lSM -lICE -lX11 -lz -lm -lgomp -lpthread
Thank you for you help !
modou
Re: problem with Magick++-config
Post by modou »
It work!
i used this command :
g++ -lMagick++ -O2 -o main main.cpp
But, i think that there's a problem in the documentation at this page http://www.imagemagick.org/Magick++/ :(
Post Reply
