Hello,
Is it possible to capture full screen of desktop including start menu, icons etc?
-window root command capture just active windows and not the start menu, icons on desktop...
Thanks
Full screen capture
mailinator
- Authentication code: 8675308
- anthony
Re: Full screen capture
As you mentioned Start menu I gather you are on Microsoft windows!
I am however not certain how -window works under Microsoft windows, as I am not a windows user.
I know how it works under X windows. The only thing I can think of is that it is a system specific thing.
Question does the microsoft screen capture ('print' key???) capture the start menu and task bar?
Anthony Thyssen -- Webmaster for ImageMagick Example Pages
https://imagemagick.org/Usage/
mailinator
Sorry, I should say that I'm using Ubuntu.
Print Screen key work (it capture desktop icons, start menu etc.).
- anthony
Well then it should work fine.. Though they don't call it a 'start menu' which is why I thought you were on microsoft windows.
Try this
this grabs the whole display, resizes by half, and displays (show:) the result.
For more info see...
http://www.imagemagick.org/Usage/files/#x
Which includes examples of grabbing, and modifying specific windows (or any window!)
Try this
convert x:root -resize 50% show:For more info see...
