HI
Greetings of the day.
I have problem while giving shadow in image. In this i have two images one generated by flash and another one is using imagemagick.
Difference between two images which created by using flash and imagemagick is that in flash we have bottom-left shadow where as by image magick it is giving top-left shadow.
I try it is giving me bottom-right or top-left shadow but i want bottom-left shadow using imagemagick.......
I WANT SAME SHADOW WHICH I GET FROM FLASH THAT IS BOTTOM-LEFT SHADOW.
PLEASE HELP ME........
there are these two images.
Image generated using flash
PLEASE HELP ME IN DOING THIS...
I am waiting for your response....
Shadow using image magick
- Authentication code: 8675308
- fmw42
- Authentication code: 1152
Re: Shadow using image magick
Use negative offset terms in your -shadow. See last example at http://www.imagemagick.org/Usage/blur/#shadow
