Git HEAD: eb56534ac870d9a5b8a6e7db8d32c0e76ae65924
OS & Compiler: Ubuntu 16.04 x64 + Clang 4.0
Command:
convert im_hoobr_omp_outlined.eps null
ASAN:
==13673==ERROR: AddressSanitizer: heap-buffer-overflow on address 0x7f76c11975f0 at pc 0x7f76cac64336 bp 0x7ffc70784a50 sp 0x7ffc70784a48
READ of size 4 at 0x7f76c11975f0 thread T0
#0 0x7f76cac64335 in .omp_outlined..68 XYZ/ImageMagick/MagickCore/resize.c:2820:28
#1 0x7f76c76cf6b2 in __kmp_invoke_microtask (/usr/local/lib/libomp.so+0x776b2)
#2 0x7f76c76891fb in __kmp_invoke_task_func (/usr/local/lib/libomp.so+0x311fb)
#3 0x7f76c768575c in __kmp_fork_call (/usr/local/lib/libomp.so+0x2d75c)
#4 0x7f76c767ae3f in __kmpc_fork_call (/usr/local/lib/libomp.so+0x22e3f)
#5 0x7f76cac5cfc2 in VerticalFilter XYZ/ImageMagick/MagickCore/resize.c:2700:11
#6 0x7f76cac5b7aa in ResizeImage XYZ/ImageMagick/MagickCore/resize.c:2957:14
#7 0x7f76caf3c649 in WriteEPTImage XYZ/ImageMagick/coders/ept.c:444:20
#8 0x7f76caa4b043 in WriteImage XYZ/ImageMagick/MagickCore/constitute.c:1114:14
#9 0x7f76caa4bacf in WriteImages XYZ/ImageMagick/MagickCore/constitute.c:1333:13
#10 0x7f76ca28135e in ConvertImageCommand XYZ/ImageMagick/MagickWand/convert.c:3280:11
#11 0x7f76ca35fd22 in MagickCommandGenesis XYZ/ImageMagick/MagickWand/mogrify.c:183:14
#12 0x4edaee in MagickMain XYZ/ImageMagick/utilities/magick.c:149:10
#13 0x7f76c709882f in __libc_start_main (/lib/x86_64-linux-gnu/libc.so.6+0x2082f)
#14 0x419ff8 in _start (/usr/local/bin/magick+0x419ff8)
0x7f76c11975f0 is located 6672 bytes to the left of 1425792-byte region [0x7f76c1199000,0x7f76c12f5180)
allocated by thread T0 here:
#0 0x4c1807 in posix_memalign /scratch/llvm/clang-4/xenial/final/llvm.src/projects/compiler-rt/lib/asan/asan_malloc_linux.cc:142:3
#1 0x7f76cabb20ba in AcquireAlignedMemory XYZ/ImageMagick/MagickCore/memory.c:262:7
#2 0x7f76ca9e6735 in OpenPixelCache XYZ/ImageMagick/MagickCore/cache.c:3561:46
#3 0x7f76ca9e94cf in GetImagePixelCache XYZ/ImageMagick/MagickCore/cache.c:1668:18
#4 0x7f76ca9ec7ad in SyncImagePixelCache XYZ/ImageMagick/MagickCore/cache.c:5266:28
#5 0x7f76caa0b0e1 in SetImageColorspace XYZ/ImageMagick/MagickCore/colorspace.c:1126:10
#6 0x7f76cae53a13 in ReadPNMImage XYZ/ImageMagick/coders/pnm.c:402:26
#7 0x7f76caa48644 in ReadImage XYZ/ImageMagick/MagickCore/constitute.c:497:13
#8 0x7f76cae5f43c in ReadPSImage XYZ/ImageMagick/coders/ps.c:943:12
#9 0x7f76caa48644 in ReadImage XYZ/ImageMagick/MagickCore/constitute.c:497:13
#10 0x7f76ca9cb295 in BlobToImage XYZ/ImageMagick/MagickCore/blob.c:450:9
#11 0x7f76caf3c0ae in ReadEPTImage XYZ/ImageMagick/coders/ept.c:252:9
#12 0x7f76caa48644 in ReadImage XYZ/ImageMagick/MagickCore/constitute.c:497:13
#13 0x7f76caa4a6bc in ReadImages XYZ/ImageMagick/MagickCore/constitute.c:866:9
#14 0x7f76ca279bb5 in ConvertImageCommand XYZ/ImageMagick/MagickWand/convert.c:641:18
#15 0x7f76ca35fd22 in MagickCommandGenesis XYZ/ImageMagick/MagickWand/mogrify.c:183:14
#16 0x4edaee in MagickMain XYZ/ImageMagick/utilities/magick.c:149:10
#17 0x7f76c709882f in __libc_start_main (/lib/x86_64-linux-gnu/libc.so.6+0x2082f)
SUMMARY: AddressSanitizer: heap-buffer-overflow XYZ/ImageMagick/MagickCore/resize.c:2820:28 in .omp_outlined..68
Shadow bytes around the buggy address:
0x0fef5822ae60: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa
0x0fef5822ae70: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa
0x0fef5822ae80: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa
0x0fef5822ae90: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa
0x0fef5822aea0: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa
=>0x0fef5822aeb0: fa fa fa fa fa fa fa fa fa fa fa fa fa fa[fa]fa
0x0fef5822aec0: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa
0x0fef5822aed0: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa
0x0fef5822aee0: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa
0x0fef5822aef0: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa
0x0fef5822af00: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa
Shadow byte legend (one shadow byte represents 8 application bytes):
Addressable: 00
Partially addressable: 01 02 03 04 05 06 07
Heap left redzone: fa
Freed heap region: fd
Stack left redzone: f1
Stack mid redzone: f2
Stack right redzone: f3
Stack after return: f5
Stack use after scope: f8
Global redzone: f9
Global init order: f6
Poisoned by user: f7
Container overflow: fc
Array cookie: ac
Intra object redzone: bb
ASan internal: fe
Left alloca redzone: ca
Right alloca redzone: cb
==13673==ABORTING
